Assembly Wizard Dialog
In MotionView, models are assembled from libraries of pre-defined systems using the Assembly Wizard, located on the Model menu. The Assembly Wizard dialog guides you through the assembly process, ensuring that your selections are compatible.
- Next
- Moves to the next panel.
- Back
- Returns to the previous panel for review or edit.
- Cancel
- Closes the Assembly Wizard.
- Reset Selection
- Resets the assembly wizard.
- Message Log...
- Displays the message log at the bottom of the dialog.
- Clear
- Clears the message log.Note: This button is only activate if the message log is displayed.
Model Type
Driveline Configuration
Primary Systems
Steering Subsystems
Springs, Dampers, and Stabars
Jounce/Rebound Bumpers
Label and Varname Specifications
Once you have made your selections, the Assembly Wizard retrieves the systems from the libraries and connects them in a hierarchical structure.
The attachments specified during the assembly process can be modified using the Attachment Wizard dialog.
