Manufacturing Solutions
Vent BC
Vent BC
Vent BC
Vent BC is used specify where the air is vented out and resin will eventually emerge out when the mold is filled (or earlier in the case of race tracking). Often, pressure is set to 0 at the vent.
Variable
Default Value
Valid Range
Data Type
Significance
PortLocation
(0, 0, 0)
Valid (x, y, z)
Constant
This is needed only if gravity is turned on.
Pressure
None
+ve value
Constant or function of time
Pressure is specified in Pa. You should specify at least Pressure or SuctionRate. If you specify both, then Pressure will be given priority.
SuctionRate
None
+ve value
SuctionRate is specified in m3/s. You should specify at least Pressure or SuctionRate. If you specify both, then Pressure is given priority.
Temperature
None
T > 273
This needs to be specified only if the Heat Transfer is on. If you specify Temperature, you should not specify heat flux and the vice versa.
HeatFlux
0
+ve, 0, or -ve value
VentBC bc_name {
PortLocation = X Y Z
( Pressure | SuctionRate ) = value
[ ( Temperature | HeatFlux ) = value ]
VentBC vent1 { PortLocation = 0.5 0.5 10.0
         Pressure = 0.0
         HeatFlux = 0.0 }
