Manufacturing Solutions
Wall BC
Wall BC
Wall BC
This BC is used at the mold walls.
Variable
Default Value
Valid Range
Data Type
Significance
Temperature
None
T > 273
Constant or function of time
This needs to be specified only if the Heat Transfer is on.  If you specify Temperature, you should not specify heat flux, and vice versa.
HeatFlux
0
+ve, 0, or -ve value
This needs to be specified only if Heat Transfer is on. If you specify Temperature, you should not specify HeatFlux and vice versa. If you specify both, then HeatFlux takes precedence.
WallBC mold_wall {
Temperature = 350
