Manufacturing Solutions
Boundary Conditions
Boundary Conditions
Boundary Conditions
This block is used to define the boundary conditions.  These include all boundaries that define the flow domain.  In HyperMold-RTM, the boundaries of the domain are classified into the following types.
InjectorBC
VentBC
WallBC
NoFlowBC
If a boundary in a domain is left unspecified, it will default to WallBC. The syntax for BOUNDARY packet is defined below.
BEGIN BOUNDARY
BC_Type BC_Name_1 {BC_Values}
END
BC_Type can take the value InjectorBC, VentBC, WallBC or NoflowBC.
BC_Values will vary depending on the BC_type.
