Manufacturing Solutions
Injector BC
Injector BC
Injector BC
This BC is used for specifying the injection locations through which resin is injected into the mold. The following data is defined in this BC.
PortLocation
Pressure
InjectionRate
ResinSaturation
ZpmActuator
Temperature
HeatFlux
DegreeOfCure
Variable
Default Value
Valid Range
Data Type
Significance
PortLocation
(0, 0, 0)
Valid (x, y, z)
Constant
This is needed only if gravity is turned on
Pressure
1.0e+06
+ve value
Constant or function of time
Pressure is specified in PA. You should specify at least pressure or injection rate. If you specify both, then pressure will be given priority. This behavior is altered by the ZpmActuator setting.
Pressure can be given as a fuction of time using table option. Tables can be created using a “Create table” macro.
InjectionRate
None
+ve value
InjectionRate is specified in m3/s. You should at specify at least pressure or injection rate. If you specify both, then pressure is given priority. However, this behavior is altered by the ZpmActuator setting. If injection rate is 0 then it will treated as a NoflowBC.
ResinSaturation
None
1
Constant
Ideally, this should be 1. The only case it can be left unspecified is if InjectionRate is 0.
ZpmActuator
-1
0 or 1
-1 means Actuator is  absent.
0 means Actuator is present, but off. This means the InjectionRate BC will be specified. Make sure that InjectionRate is set to 0.0
+1  means Actuator is on and pressure condition is applied.
Temperature
300.0
T > 273
This needs to be specified only if the Heat Transfer is on. Unless you are using ZpmActuator, do not specify heat flux and temperature together.
HeatFlux
None
+ve, 0 or -ve value
DegreeOfCure
0
0 - 1
Ideally, this would be 0 at the gate.
Injector BC with Pressure as a constant value
InjectorBC gate {
PortLocation = 0.5 0.5 0.0
Pressure = 2.0E+05
Saturation = 1.0
Temperature = 473.0
Injector BC with Pressure as a function of time
InjectorBC gate {
Pressure = tableName
Saturation = 1.0
Temperature = 473.0
If the pressure is defined as a function of time, the pressure values need to define in the form of table and the table data need to written under FUNCTIONS section as shown below
BEGIN FUNCTIONS
 TABLE1        tableName {
                 0.0        1.0E+01
                 5.0        1.0e+03
                 10.0        1.0E+04
                 15.0        1.0E+06
                 1000.0        1.0E+06
END
