Manufacturing Solutions
Supported Element Property Cards
The following element property cards are supported in the Moldflow user profile. Full support is available only for UDM-formatted (MPI 4.0 or later) export files. Only limited support is provided for the MFL file format.
Feed system and cooling circuit (based on beam elements) cards are supported by the Design Circuit macro; all other cards are supported by the Edit Prop Cards macro.
Part surface – midplane  (tria3)
Part surface – fusion (tria3)
Tetrahedron (flow3d)
Feed system with beam elements
-Cold sprue
-Cold runner
-Cold gate
-Hot sprue
-Hot runner
-Hot gate
Cooling circuit with beam elements
-Channel
-Baffle
-Bubbler
-Thermal pin
-Hose
Feed system with tria3 elements
-Cold gate surface – midplane
-Hot gate surface – midplane
-Cold sprue surface – fusion
-Cold runner surface – fusion
-Cold gate surface – fusion
-Hot sprue surface – fusion
-Hot runner surface – fusion
Miscellaneous
-Connector
-Overflow well – beam element
-Overflow well – shell element
-Part beam
-Compression surface
-Preform surface – midplane
-Preform surface – fusion
-Wire
-Lead frame
-Mold block surface
-Mold insert surface
-Part insert (midplane)
-Part insert surface – fusion
-Part insert 3D
-Parting surface
-Over molding 2nd component 3D
See Also:
Edit Prop Cards Submenu
Design Circuit Submenu
Diagnostics Submenu
