Manufacturing Solutions
Edit Prop Cards Submenu
The Edit Prop Cards submenu contains the following macros:
editpropcards_menu
Create/Edit Property Card
Create & Assign Property Card
Opens the Create Property Card dialog, where you can create a property card based on one of many included property types. You can also assign it to specified elements.
Edit Property Card
Opens a selector for property cards so you can edit an existing property card.
Assign Existing Property Card
This macro allows you to assign any existing property card to the selected elements.
Edit Element Data
Opens a selector for elements so you can edit the property card of a selected element.
<<< Back
Opens the main Moldflow Utility menu.
See Also:
Moldflow Utility Menu
