Manufacturing Solutions
Diagnostics Submenu
Diagnostics Submenu
Diagnostics Submenu
The Diagnostics submenu contains the following macros:
diagnostics_menu
Diagnostics
Convert Comp Cards
Converts component card images into property cards and assigns them to the elements in that component. This conversion is provided for backward compatibility.
Overlapping Elements
Checks for overlapping elements in the model.
Mesh Match Ratio
Computes the mesh match ratio.
Occurrence Number
Creates a contour plot of the model’s occurrence number.
Mesh Thickness
Creates a contour plot of element thickness
Aspect Ratio
Creates a contour plot of aspect ratio of elements. This calculation is computed using the Moldflow formula.
Check Element Property
This macro identifies elements that have a missing property card. It reports the number of such elements and also highlights those elements.
Summary
Opens the Model Information dialog, which lists statistics about the current model, including part volume and the projected area in the XY plane.
Contours
Tools
Split BC Tets
Splits the Tet4 elements on the boundaries that have more than one face on the boundary condition.
Organize Elements
Opens the Organize Elements dialog, from which you can organize elements based on thickness or element type.
<<<Back
Opens the main Moldflow Utility menu.
See Also:
Moldflow Utility Menu
