Manufacturing Solutions
Save and Export the Model
The last checkbox on the Plate Meshing Wizard tab is Save and Export the Model.
This dialog helps you create HyperXtrude data files and launches the solver.
hx_0155_09
See Also:
Select Model Units
Select and Assign Material
Set Analysis Requirements
Generate Polymer Mesh (Starting with Solids)
Generate Polymer BCs
