Manufacturing Solutions
Generate Polymer Mesh (Starting from Solids)
The next checkbox in the Plate Meshing Wizard is Generate Polymer Mesh.
If you start with solids, then this macro will be used to generate mesh.
plate_meshing_wizard_06
