Manufacturing Solutions
Generate Polymer BCs
The next checkbox on the Plate Meshing Wizard tab is Generate Polymer BCs.
This macro is used to create all the BCs and assign process conditions. Please inspect the BC data and make appropriate changes (if needed) before submitting the data for analysis.
