Manufacturing Solutions
Importing Data
Importing Data
Importing Data
You can import several types of data to begin your design in the Moldflow user profile: Moldflow MPI input decks, external CAD files (see Import tab for a list of supported file types), and HyperMesh files. The Import Data group of the Utility Menu provides buttons for each of these options.
Using the Import tab
1.To import a Moldflow MPI input deck (*.udm), click on the Import icon fileImportSolver-24on the toolbar, or click File > Import > Solver Deck. The Import tab opens.
Import_dialog
2.Specify the file to import.
3.Select the MPI model unit and HM model unit.
4.Click Import.
Using the Utility Menu
To import/load the model, click the button under the Import Data group that corresponds to the type of input file you have.
moldflow2
If you choose MPI, the Import Moldflow Data Files dialog box appears. Click the file_icon_2 button to browse for the file and click Import. This option is the same as using the Import icon functionality described above.
moldflow3
The following options are available on the Import Moldflow Data Files dialog box:
Option
Project file
The name of the imported file:
Moldflow ASCII UDM file (MPI 4.0 or higher) .udm extension or .mfl for MPI 2.0 files. There are four other files that are exported along with this file (files with extensions .ela, .nda, .ata, and .ain).
MPI format
UDM or MFL, depending on the version of the project file you selected in the Project file field.
MPI model units
The unit used in the Moldflow data deck (typically, meters).  Select one of the following units:  inches, millimeters, meters, or centimeters.
HM model units
The unit used in the HyperMesh deck (typically, inches or millimeters).  Select one of the following units:  inches, millimeters, meters, or centimeters.  It is best to use the unit that is intuitive for the model.
If you choose CAD or HM, the Files panel appears. Click retrieve to select an input file, and then click Open.
Note:If you open a Moldflow deck that was created in version 6.0 of HyperMesh, click Convert Comp Cards to update the database to the current database format. For more information about this conversion, see Data Conversion.
See Also:
Data Conversion
Moldflow Utility Menu
