Manufacturing Solutions
Feed Design
Feed Design
Previous topic Next topic Expand/collapse all hidden text
Feed Design
Creating the Feed System
The Create Feed System macro assists in creating a feed system (also known as runner system). This macro creates property cards for the selected elements that make the runner system and supports all the beam elements that make up the feed system and the associated taper/cross-section options. The following options are available in the Create Feed System dialog:
Feed Element:
Element can be of one of the following types: Sprue, Runner, or Gate.  Depending on the selection, the cross-section option could take different values.  For instance, Moldflow allows only a circular section of cold sprue.
moldflow13
Hot or cold:
This option takes the value Hot or Cold. In the UDM format, different element cards support them. That is, two different property cards define cold sprue and hot sprue. However, while exporting it in MPI 2.0 format, this is identified by the color of element. This issue is handled internally.
Taper type:
The taper type can be one of the following: None, Ends, or Angle.  For None there is no taper. If the taper is specified using Angle, the starting dimension and the taper angle is specified.  For Ends, dimensions at both ends of the element selection should be specified.
The taper is applied to all the elements in the selection and the macro prompts you to enter the starting element.  The elements in the selection must be continuous.
Occurrence number:
Defines the symmetry in the multi-cavity mold.  See About Occurrence Numbers for more details.
Cross-section:
Feed elements can have one of the following shapes as the cross-section: Circular, Annular, Half-circular, Trapezoidal, Other-shape, or Rectangular.  There are restrictions on the shapes taken by sprue: cold sprue can be circular and hot sprue can be circular or annular.  These are restrictions in Moldflow.
Dimension:
Based on the taper and cross-section choices, the dimension entries are resized and displayed.
Besides creating the property cards, the macro also creates solids to highlight the shapes.  It should be noted that shapes supported are half-circular, trapezoidal, circular, rectangular and annular. Also, the coupling between the surfaces and elements is a weak coupling.  That is, deleting the element or solid will not delete the other.  It will be redrawn only if the properties are altered through the macro.
Editing Feed System Solids
Click Edit Solid Data to select a feed solid to edit. The feed data given during the creation of the solid is populated in the Edit Feed System dialog.  You can change the values and click Update to set the new values to the feed solid. If multiple solids are selected, then the first solid is considered for editing.
Editing Feed System Element Data
Click Edit Element Data to select an element whose property card you want to edit. Once you select an element, the associated property’s name and type appear in a popup dialog. Click Update and the property’s card image opens for editing in the main menu area, where you can change the values in the fields for that property.
How Do I…
expand-green-10Create a feed system:
1.Design the feed system:
-        Draw your feed system using lines.
-Use the Line Mesh panel in HyperMesh to mesh the drawing.  You can access this panel by clicking Beams under Generate Mesh in the Utility menu. Alternatively, you can specify the number of elements to be created on the line while creating the feed system by setting the selection to Lines instead of Elements.
2.Click Feed under Design Circuit to design the feed system.
3.Create properties cards and automatically assign them to elements:
-Set the feed properties.  In the following image, a cold gate of rectangular cross-section with no taper and an occurrence number of 4 is selected. Set the selection to Lines and specify number of elements as 3.
-Click Create. The dimensions of the gate are 2mm by 4mm, so type 2 in the Width field and 4 in the Height field.
-Select the line.
-Click proceed.
moldflow19
See Also:
Cooling Circuit Design
HyperMold Overview
