Manufacturing Solutions
Element Quality Review Configuration Dialog
In the Element Quality View Configuration dialog, you can customize the appearance of the Element Quality View tool, and select the criteria that appears in the Multiple Criteria legend. To open this dialog, click Configure Quality View from the right-click Element Quality Review menus.
The list below describes the behavior of each option in the Element Quality View Configuration dialog.
edit criteria
Opens the Criteria File Editor.
Note:You must click OK or Apply to accept modified criteria, otherwise any changes will not be applied.
Default
Sets back the current configuration to the default configuration.
Apply
Accepts the modifications made and applies them to the Element Quality View, while keeping the Element Quality  View Configuration dialog open for further changes to be made.
Note:You cannot make changes directly to the Multiple Criteria and single criteria legends while the Element Quality  View Configuration dialog is open.
OK
Closes the Element Quality View Configuration dialog after accepting the modifications made and applies them to the Element Quality View.
Cancel
Closes the Element Quality View Configuration dialog without making any modifications in the Element Quality View.
element_quality_view_configuration_dialog
The Element Quality View Configuration dialog contains a list of all possible 2D element criteria that you can display in the Multiple Criteria legend. To select which 2D element criteria you would like to display in the Multiple Criteria legend, select or clear each element criteria's check box. Click the blue up and down arrows to rearrange the order the 2D element criteria will appear in, in the Multiple Criteria legend.
Note:If you change the order of the element criteria after you have adjusted the threshold values in the Multiple Criteria legend, the threshold values will reset to their fail values. It is best to change the order of the element criteria first, and then change the threshold values in the Multiple Criteria legend.
You can change the display color of each criteria in this dialog by selecting a new color from the color pallet.
See Also:
Element Quality Review Context Menus
