Manufacturing Solutions
Visualization Toolbar
The Visualization toolbar controls the rendering of entities in the graphics area, and includes settings for geometry and mesh color mode. You can turn on/off the Visualization toolbar from View > Toolbars.
vis_toolbar
The detailed behavior of each tool button is described in the following table:
Button
Left-click
LEFT Behavior
Right-click
RIGHT Behavior
by_auto
Pick a different mode
Automatically selects one of the following color modes based on the currently active panel.
You can change all of the colors in the Options > Colors panel. To access this panel, click Preferences > Colors from the menu bar, or press <o>.
Same
by_assembly_geom
All surfaces are colored based on the assemblies they belong to. Each assembly receives a different color (although models with many assemblies may have colors repeated for more than one assembly). Any surfaces that do not belong to an assembly are colored gray.
To change an assembly's color, right-click its color box in the Model browser or Entity Editor and select a new color.
Same
by_comp
Changes the color of all surfaces and solid faces to the color assigned to the component in which that geometry resides. All surface edges and solid face edges are colored black.  A component's color can be changed in the Model Browser > Component View.
Same
by_topo
Surfaces are colored gray (2D faces (topo) with surface edges colored by topology: red (free edges), green (shared edges), yellow (t-junctions), or blue (suppressed edges).  Solid faces and face edges are colored transparent green (bounding faces) with internal faces colored yellow (full partition faces).
Same
by_2d_topo
Surfaces are colored gray (2D faces (topo) with surface edges colored by topology: red (free edges), green (shared edges), yellow (t-junctions), or blue (suppressed edges).  Solid faces and face edges are colored blue, ignoring solid topology.
Same
by_3d_topo
Surfaces and surface edges are colored blue, ignoring surface topology.  Solid faces and face edges are colored transparent green (bounding faces) with internal faces colored yellow (full partition faces).
Same
mixed
Surfaces are colored by component with surface edges colored by topology.  Solid faces are colored by component with solid face edges colored by topology.
Same
new_mappable
Surfaces display in wireframe mode, with surface edges colored blue (ignoring topology).  Solid faces are colored by mappability: red (not mappable), yellow (1d mappable), or green (3d mappable).  Solid face edges are colored by topology.
Same
visualizationGeometryShadedWithEdges-24
Shaded Geometry with Surface Edges
Button: set geometry mode to shaded with surface edges.
Arrow (lower-right): Select option from menu
Same
visualizationGeometryShaded-24
Shaded Geometry
Button: set geometry mode to shaded.
Same
visualizationGeometryWireframeWithSurfaceLines-24
Wireframe Geometry with Surfaces Lines
Button: set geometry to wireframe with surface lines.
Same
visualizationGeometryWireframe-24
Wireframe Geometry
Button: set geometry to wireframe mode.
Same
visualizationTransparency-24
Transparency
Opens the Transparency panel.
Same
by_comp2
All elements are colored by the color assigned to the component in which that element resides.  A component's color can be changed in the Model Browser by right-clicking its color box and picking a new color.
Same
by_prop2
All elements are colored by the property assigned to that element.  Properties are assigned to elements directly or indirectly.  Properties are assigned directly to the element by using the Property > Assign panel.  Indirect element properties are inherited from the component in which the element resides; component properties are assigned in the Component > Assign panel.  Directly assigned properties override indirect ones.  Solvers in group #1 (RADIOSS (Bulk Data), OptiStruct, Nastran) can support both direct and indirect element property assignment.  Solvers in group #2 (RADIOSS (Block), LS-DYNA) only support indirect element property assignments.  Any element without a property is colored gray.  A property's color can be changed in the Model Browser by right-clicking its color box and picking a new color.
Same
by_mat2
All elements are colored by the material assigned to that element.  Materials are assigned to elements differently for solver group #1 and solver group #2;  Solver Group #1 (RADIOSS (Bulk Data), OptiStruct, Nastran) assign materials to properties, and then properties to elements (either directly or indirectly as discussed in Color by Property).  Elements with both direct and indirect property assignments use the material associated with the direct element property assignment.  Solver group #2 (RADIOSS (Block), LS-DYNA) assigns materials to elements indirect by assigning materials to the component in which the element resides using the Component > Assign panel.  Any element which does not have a material assigned to it, directly or indirectly, will be colored gray.  A material's color can be changed in the Model Browser by right-clicking its color box and picking a new color.
Same
by_assem2
All elements are colored based on the assemblies they belong to.  Each assembly receives a different color (although models with many assemblies may have colors repeated for more than one assembly).  Any elements that do not belong to an assembly are colored gray.  An assembly's color can be changed in the Model Browser by right-clicking its color box and picking a new color.
Same
by_1d2d3d
All elements are colored by their topology: green (1D), blue (2D), and red (3D).
Same
by_config
All elements are colored by their element configuration (mass, reb2, spring, bar, rod, gap tria3, quad4, tetra4, etc.).  An element's configuration color can be changed from the Element Types panel.
Same
by_thickness
Shell elements are colored according to their thickness values (element or node); if no thickness is specified for any element or node, then they will all be the same color. However, elements with thickness values are colored individually according to their thicknesses. A key to indicate which thickness corresponds with each color displays in the corner of the graphics area. If the element is assigned with nodal thickness, then the nodes will be colored based on the thickness.
nodal_thickness
Element Thickness 2D Detailed Representation
element_thickness
Nodal Thickness 2D Detailed Representation
This feature works in conjunction with the 2D Detailed Element display option described below.
Same
element_by_quality
Left-click the tool button to open the Element Quality View mode in the graphics area.
This permanent mode serves as a useful tool to investigate each specific element criteria, as well as evaluate the overall quality of a mesh.
Same
by_domain
All elements are colored based on the domains they belong to. A domain is a morphing entity which enables design changes to an existing FE topology. Each domain receives a different color. Any elements that do not belong to a domain are colored gray. A domain color can be changed in the Model Browser by right-clicking its color box and picking a new color.
Same
visualizationElementsShadedWithMesh-24
Shaded Elements with Mesh Lines
Set current element visual mode to shaded with mesh lines.  Elements are shaded, and surface mesh lines display.
Left-click the lower right arrow to expand the Options Menu.
Right-click to expand Options Menu; Left-click an icon to set new current icon and perform icon’s left behavior.
visualizationElementsShadedWithFeatures-24
Shaded Elements with Feature Lines
Set current element visual mode to shaded with feature lines. Elements are shaded but have no mesh lines, while feature lines display.
visualizationElementsShaded-24
Shaded Elements
Set current element visual mode to shaded. Elements are shaded, but no lines display.
visualizationElementsWireframeSkinOnly-24
Wireframe Elements (skin only)
Set the current element visual mode to wireframe (skin only).  Internal mesh lines will not display.
visualizationElementsWireframe-24
Wireframe Elements
Set the current element visual mode to wireframe.  Internal and surface mesh lines display.
visualizationElementsTransparent-24
Transparent Elements and Feature Lines
Set current element visual mode to transparent with elements and feature lines.  Elements are shaded but transparent, no mesh lines display, but feature lines do.
1d_traditional_element_representation
1D Traditional Element Representation
Display a simple representation for 1D beam elements.
1d_detailedl_element_representation
1D Detailed Element Representation
Display a more detailed, shaped-based representation for 1D beam elements.
1d_detailed_traditional_element_representation
1D Traditional and Detailed Element Representation
Display both the simple and detailed representations for 1D beam elements.
2d_traditional_element_rep
2D Traditional Element Representation
Display a simple representation for 2D shell elements.
2d_detailed_element_rep
2D Detailed Element Representation
Display a more detailed, shaped-based representation for 2D shell elements.
2d_detailed_traditional_element_rep
2D Traditional and Detailed Element Representation
Display both the simple and detailed representations for 2D shell elements.
visualizationPlyStandard-24
Layers off
Ply layers are not displayed.
visualizations_composite_nolayers_simple
Right-click to expand Options Menu; Left-click an icon to set new current icon and perform the icon’s left behavior.
visualizationPlyThickness-24
Composite layers
Plies in a composite material are displayed.
visualizations_composite_layers_simple
The exact nature of the display depends on the 2D Element Representation button. See Element and ply visualization for details.
For continuum shells the display can be overlaid with the transparent representation of the original continuum shell elements, if 2D Traditional Element Representation (2d_traditional_element_rep) is turned on.
visualizationPlyThicknessWithDirection-24
Composite layers with fiber direction
Display layers with vectors indicating their appropriate ply orientation.  Corrected fiber directions are shown if the drape data is available on every element of the ply.
visualizations_composite_layers_fibers_simple
The exact nature of the display depends on the 2D/3D element visualization button. See Element and ply visualization for details.
layer_edges_icon
Layer Edges
Enables the ply lay-up or stack boundaries to be visualized, which provides an easy way to view ply drop-off. When the stack topology shape is changed, the visualization of the edges is automatically updated. Ply layer geometry edges are always outlined in white, where as FE edges are always outlined in  the same color as the ply. FE edges are always outlined with a thicker line compared to geometry edges.
visualizationElementsShrink-24
Shrink Elements
Left-click the tool button to toggle on/off shrink elements by shrink factor.  Shrink factor can be set from the Options > Graphics panel.  The Options panel can be accessed from the menu bar from Preferences > Graphics.
Same
visualization-24
Visualization Options
Left-click the tool button to open Visualization Controls tab.
Same
