Manufacturing Solutions
Designing Circuits
Designing Circuits
Designing Circuits
The next step in the process is to design the elements of a feed system or cooling circuit. The Design Circuit submenu of the Utility menu, shown below, provides macros for both feed system and cooling circuit creation in addition to macros for editing property cards and element data.
designcircuit_menu
Before you create a circuit, you should have already drawn the feed system or cooling circuit with lines and meshed the entire feed system or cooling circuit with rod (61) elements.
Feed System Design
Cooling Circuit Design
See Also:
Moldflow Utility Menu
