Loads
Load management and configuration.
New Load Management
Introduction
Nastran and OptiStruct allow loading and boundary conditions to be defined on finite elements. These loads and boundary conditions are commonly applied as distributed loads. Because of their distributed nature, loads and boundary conditions must be carefully applied on individual FE elements. The repetitive nature of FE modeling development creates the overhead of applying loading and boundary conditions for each repetition of new mesh data. New load management aims to simplify this process and solve the problem of redefining loads.
Advantages
HyperMesh creates a load entity for each load solver keyword. Classic load entities can be defined on set entities by defining the underlying region of FE elements, but they cannot address all of the issues of distributed loads. Some of the limitations of classic load support are:
  • Defining distributed values for loads defined on set entities
  • Overhead creation and management of load entities on each FE location
  • Dependency of FE locations for load creation
  • Limitations of supporting complex boundary condition cards with multiple DOF definitions
The new load management technology offers the following advantages:
  • Consolidation of loads by common attributes such as SID, Magnitude, etc.
  • Interrogation of loads is more powerful
  • Advanced load option support:
    • Applying pressure on Nodes
    • Applying traction on axisymmetric elements
    • Applying pressure on 1D elements based on element orientation
  • Honoring solver recommendations such as Load on Set
  • Enhancements to the Solver Browser to handle large numbers of loads
  • A uniform way to set up a model (end-to-end) through the browser
Objectives
Besides providing a simplified common workflow for managing loads, other engineering load objectives include:
  • Supporting region independent loads
  • Defining distributed values for loads defined for each FE location in a set
  • Adding complete support for all solver cards mapped to classic loads
Classic Load Absorption
Loads created from the panel are called classic loads. Although classic load entities are still supported, their use is not encouraged. New load management allows you to create loads from the Solver Browser. Using the "absorbloads" command, classic load entities can be absorbed into engineering entities.
Advanced Segregation
The advanced segregation feature allows you to spawn new engineering loads from existing engineering loads based on value distribution or topology. You can set up a single load with distributed values and run the "absorbentities" command to obtain multiple meaningful and manageable loads of the same magnitude value.
Realization
A realization command is provided for those who choose to work with classic loads. The "realizefieldloads" command creates classic loads from engineering loads, although it is not the exact reversal of the absorption command.
Load Visualization
Load plotting allows for visualization of distributed load values on an FE region. Different plotting types provide different views of the load.
  • Vector Plots – display value distribution with the direction of the load
  • Advanced Contour Plots – display value distribution with interactive filters
  • Contour Plots – display value distribution with respect to the entire model
    Figure 3.
Load values can be plotted at specific time stamps for curve-based time dependent loads.
Every load and constraint must be organized into one load collector, and therefore are mutually exclusive to a load collector.
Load Configurations
Load entities have an associated load configuration. A load configuration determines how to draw, store, and work with a load.
Accelerations
Configuration 9 - Acceleration荷重(加速度)は、モデル上に加速度(length/time2)を定義するのに使用します。
加速度は、modeling window内の末端にAの文字がついたベクトルとして表示されます。
Constraints
Configuration 3 - Constraints allow for constrained degrees of freedom to be defined on the model.
Constraints are displayed with a triangle that connects to the node, with the dof numbers that apply to the node beside the triangle in the modeling window.
Fluxes
Configuration 6 - Flux loads are defined as an amount that flows through a unit area per unit time (amount/length2/time). Fluxes are typically used in modeling transport phenomena such as heat transfer, mass transfer, fluid dynamics, and electromagnetism.
Fluxes are displayed as a thick arrow labeled with the word "flux" in the modeling window.
Forces
Configuration 1 - Force loads allow for a concentrated force (mass*length/time2) to be applied to the model.
Forces are displayed as a vector with the letter F at the tail end in the modeling window.
Moments
Configuration 2 - Moment loads allow for a concentrated moment (length*force) to be applied to the model.
Moments are displayed with a double-headed vector with the letter M at the tail end in the modeling window.
Pressures
Configuration 4 - Pressure loads allow for a pressure (force*length2) to be applied to the model.
For most solvers, the pressure load is considered as force/area, therefore the magnitude of the pressure is multiplied by the calculated area of the elements to which it is applied and resolved as concentrated force loads at the associated nodes.
Pressures are displayed as a vector with the letter P at the tail end in the modeling window.
Temperatures
Configuration 5 - Temperature loads allow for a concentrated temperature to be applied to the model.
Temperatures are displayed as a vertical line with the letter T at the top in the modeling window.
Velocities
Configuration 8 - Velocity loads allow for a velocity (length/time) to be applied to the model.
Velocities are displayed as a vector with the letter V at the tail end in the modeling window.
Abaqus Cards
Loads or constraints that are to be used as history data (under *STEP) should be collected into load collectors with the HISTORY card image. These load collectors also need to be added to the corresponding load steps (*STEP). In contrast, loads or constraints for model data should be collected into load collectors with INITIAL_CONDITION card image. They will automatically be written out in the model portion of the Abaqus input deck.
Note: All loads and boundary conditions on sets can be expanded to individual nodes and elements by selecting the Expand load on sets option in the File Options dialog, which is invoked upon importing a solver deck. If a **HMLOAD_SETS_EXPAND comment is found in the input file, all loads and boundary conditions on sets are expanded to individual nodes and elements.
Card Supported Load Types Description
*BASE MOTION Constraint Defines scale factor and DOF for dynamic loads.
*BOUNDARY (electric potential, dof 9) Flux Specifies flux boundary conditions for piezoelectric analysis.
*BOUNDARY (structural) Constraint Creates structural boundary conditions.
*BOUNDARY
(temperature, dof 11)
Temperatures Specifies temperature boundary conditions.
*CECHARGE Flux Specifies concentrated electric charges for piezoelectric analysis.
*CECURRENT Flux Specifies concentrated current in electric conduction.
*CFLUX Flux Specify concentrated fluxes in heat transfer or mass diffusion analyses.
*CLOAD Force Creates concentrated forces.
*CLOAD Moment Creates concentrated moments.
*COUPLING Constraint Define a surface-based coupling constraint
*DECHARGE Pressure Distributes electric charges for piezoelectric analysis.
*DFLUX Pressure Specify distributed fluxes in heat transfer or mass diffusion analyses.
*DISTRIBUTING Constraint Define a distributing coupling constraint
*DISTRIBUTING COUPLING Elements Specify nodes and weighting for distributing coupling elements
*DLOAD Pressure Specifies distributed loads
*FILM Pressure Define film coefficients and associated sink temperatures.
*KINEMATIC Multi-point Constraints Define a kinematic coupling constraint
*KINEMATIC COUPLING Multi-point Constraints Constrain all or specific degrees of freedom of a set of nodes to the rigid body motion of a reference node
*MPC Multi-point Constraints Define multi-point constraints
*RADIATE Pressure Specify radiation conditions in heat transfer analyses
*TEMPERATURE Temperature Specifies predefined temperature field.
ANSYS Cards
BF Flux Defines a nodal body force load.
BF_FLUE Flux
BF_HGEN Flux
BF_TEMP Temperatures
BFE_FLUE Flux Defines an element body force load.
BFE_HGEN Flux
BFE_TEMP Flux
CE_STRUCT Equation
CE_THERM Equation
CE_MAG Equation
CE_ELEC Equation
ConvBulkTe Pressure
ConvFilmCo Pressure
D_A Constraint Vector magnetic potential.
D_CONSTRNT Constraint Defines DOF constraints at nodes.
D_MAG Constraint Scalar magnetic potential.
D_PRES Constraint
D_TEMP Temperature
D_VOLT Constraint
F_FLOW Flux Specifies force loads at nodes.
F_HEAT Flux
FLOTRAN Pressure Specifies "FLOTRAN data settings" as the subsequent status topic.
Note: FLOTRAN surface load label “FSI [fluid-structure interaction flag]” is available under pressure load.
You must use DOF1 to add value for this label.
FORCE Force Selects the element nodal force type for output.
FORCE2 Moment
FSI Pressure
HFLUX Pressure
IC_A Constraint
IC_CONSTRN Constraint Specifies initial conditions at nodes.
IC_MAG Constraint
IC_PRES Constraint
IC_TEMP Temperature
IC_VOLT Constraint
PRESSURE Pressure
RDSF_EMI Pressure
RDSF_ENCL Pressure
SFE
  • Pressure
  • Convection
  • Heatflux
Defines elemental surface load.
Note: Structural, thermal and Fluid labels are covered.
SFE
  • Structural
  • Thermal
  • Fluid
Surface load
  • Structural label: PRES
  • Thermal label: CONV, HLFUX
  • Fluid label: FSI
LS-DYNA Cards
Several load types cause three cards to be output for x, y, and z components. During input, these are grouped into one load. Loads cannot be applied to sets, components, or boxes. Load curves are input and output. Use the Card Editor to select load curves. Unless mentioned in the Notes column, load cards cannot be edited.
*BOUNDARY_PRESCRIBED_MOTION_NODE Constraints
  • Type 2; Card 26, VAD = 2
  • DEATH
  • BIRTH
Define an imposed nodal motion (velocity, acceleration, or displacement) on a node or a set of nodes.
DOF 4, -4, 8, -8, 9, -9, 10, -10, 11, -11 are not supported.
*BOUNDARY_PRESCRIBED_MOTION_NODE Velocity
  • Type 1; Card 26;
  • VAD = 0
*BOUNDARY_PRESCRIBED_MOTION_NODE Acceleration
  • Type 1
  • Card 26
  • VAD = 1
*BOUNDARY_PRESCRIBED_MOTION_NODE_(ID) Velocity
*BOUNDARY_PRESCRIBED_MOTION_NODE_(ID) Constraints
  • dynaName
  • DEATH
  • BIRTH
*BOUNDARY_PRESCRIBED_MOTION_RIGID
  • PID
  • DOF
  • VAD
  • LCID
  • SF
  • VID
  • DEATH
  • BIRTH
RIGID_LOCAL and _SET options are supported.
*BOUNDARY_PRESCRIBED_MOTION_RIGID_ID
  • Dyna_Name
  • PID
  • DOF
  • VAD
  • LCID
  • SF
  • VID
  • DEATH
  • BIRTH
*BOUNDARY_PRESCRIBED_MOTION_RIGID_LOCAL
  • PID
  • DOF
  • VAD
  • LCID
  • SF
  • VID
  • DEATH
  • BIRTH
  • Title
*BOUNDARY_PRESCRIBED_MOTION_RIGID_LOCAL_ID
  • Dyna_Name
  • PID
  • DOF
  • VAD
  • LCID
  • SF
  • VID
  • DEATH
  • BIRTH
*BOUNDARY_PRESCRIBED_MOTION_SET
  • NSIDDOF
  • VAD
  • LCID
  • SF
  • VID
  • DEATH
  • BIRTH
  • TITLE
*BOUNDARY_PRESCRIBED_MOTION_SET_ID
  • Dyna_Name
  • NSID
  • DOF
  • VAD
  • LCID
  • SF
  • VID
  • DEATH
  • BIRTH
*BOUNDARY_SPC_NODE Constraints
  • Type 1; Card 13 SPC
  • CID
Define nodal single point constraint
*BOUNDARY_SPC_NODE_(ID) Constraints
  • dynaName
  • CID
*BOUNDARY_TEMPERATURE_NODE Temperature
  • LCID
  • LOC
Define temperature boundary conditions for a thermal or coupled thermal/structural analysis.
*CONSTRAINED_GLOBAL Constraints Define a global boundary constraint plane.
*INITIAL_TEMPERATURE_NODE Temperatures
LOC
Define initial nodal point temperatures using nodal set IDs or node number.s
*INITIAL_VELOCITY
  • Type 2
  • Card 30
  • INITV = 3
Define initial nodal point translational velocities using nodal set IDs.
For structured output, global velocity is set to 0.0. For structured input, non-zero values for INITV = 1 or INITV = 5 create velocities. INITV values of 2, 4, 6, and 7 are ignored.
*INITIAL_VELOCITY_NODE Rotation Define initial nodal point velocities for a node.
*LOAD_BEAM_ELEMENT Pressure Defines load on beam elements
*LOAD_MASK N/A Apply a distributed pressure load over a three-dimensional shell part
*LOAD_NODE_POINT Force
  • Type 1
  • Card 23
  • Point Loads
  • FollowerForce
Apply a concentrated nodal force to a node or a set of nodes.
LS-DYNA Load Configs 1, 2, 3 and 4
A load curve can be selected for these loads.
*LOAD_NODE_POINT Moment
  • Type 1
  • Card 23
  • Point Loads
LS-DYNA Load Configs 5, 6 7 and 8.
*LOAD_SEGMENT Pressure
  • LCID
  • AT
Apply the distributed pressure load over one triangular or quadrilateral segment defined by four, six or eight nodes.
*LOAD_SEGMENT_ID Pressure
  • LCID
  • AT
*LOAD_SHELL_ELEMENT Pressure
  • AT
  • LCIDoption
Apply the distributed pressure load over one shell element or shell element set.
*LOAD_SHELL_ELEMENT_ID Pressure
  • LCID
  • AT
*LOAD_SHELL_PRESSURE Pressure
  • Type 2
  • Card 24
  • Pressure BC
*LOAD_THERMAL_CONSTANT_NODE Temperature
N/A
Define nodal sets giving the temperature that remains constant for the duration of the calculation.
*LOAD_THERMAL_VARIABLE_NODE Temperature
  • TS
  • LCID
Define nodal temperature that is variable during the calculation.
Nastran Cards
Note: Other loads such as SPCADD, MPCADD, FREQ, FREQ1, EIGR, EIGRL, EIGC, EIGP, EIGB, GRAV, and RFORCE are supported as load collectors.
ASET Constraints Defines degrees-of-freedom in the analysis set (a-set)
ASET1 Constraints Defines degrees-of-freedom in the analysis set (a-set)
BNDFIX1 Constraints Defines analysis set (a-set) degrees-of-freedom to be fixed (b-set) during generalized dynamic reduction or component mode synthesis calculations.
BOLTFOR Flux
BSET1 Constraints Defines analysis set (a-set) degrees-of-freedom to be fixed (b-set) during generalized dynamic reduction or component mode synthesis calculations.
CSET1 Constraints Defines analysis set (a-set) degrees-of-freedom to be free (c-set) during generalized dynamic reduction or component modes calculations.
DAREA Constraints Defines scale (area) factors for static and dynamic loads. In dynamic analysis, DAREA is used in conjunction with RLOADi and TLOADi entries.
DEFORM Flux Defines enforced axial deformation for one-dimensional elements for use in statics problems.
FORCE Force Requests the form and type of element force output or particle velocity output in coupled fluid-structural analysis.
MOMENT Moment Defines a static concentrated moment at a grid point by specifying a scale factor and a vector that determines the direction.
OMIT1 Constraints Defines degrees-of-freedom to be excluded (o-set) from the analysis set (a-set).
PLOAD Pressure Defines a uniform static pressure load on a triangular or quadrilateral surface comprised of surface elements and/or the faces of solid elements.
PLOAD1 Pressure Defines concentrated, uniformly distributed, or linearly distributed applied loads to the CBAR or CBEAM elements at user-chosen points along the axis.
PLOAD2 Pressure Defines a uniform static pressure load applied to CQUAD4, CSHEAR, or CTRIA3 two-dimensional elements.
The THRU field is supported for feinput only. On export, additional pressure cards for the range specified are written.
PLOAD4 Pressure Defines a pressure load on a face of a CHEXA, CPENTA, CTETRA, CTRIA3, CTRIA6, CTRIAR, CQUAD4, CQUAD8, or CQUADR element.
Unequal nodal pressures are now supported. The average pressure value is used as the magnitude of the pressure for visualization only. The individual field values, P1-P4, can be viewed or edited using the card editor.
Updating the magnitude of pressure from the Pressures panel will have no effect on PLOAD4 cards defined using unequal nodal pressures.
QBDY1 Flux Defines a uniform heat flux into CHBDYj elements.
QSET1 Constraints Defines generalized degrees-of-freedom (q-set) to be used for generalized dynamic reduction or component mode synthesis.
QVOL Flux Volume Heat Addition - Defines a rate of volumetric heat addition in a conduction element.
SPC Constraints Defines a set of single-point constraints and enforced motion (enforced displacements in static analysis and enforced displacements, velocities or acceleration in dynamic analysis).
Constraints on nodes are supported through SPC cards. PS field in GRID card is not supported. Upon import, any PS entry on the GRID card will be converted into an SPC card.
SPC1 Constraints Defines a set of single-point constraints.
Supported for feinput only. On export, equivalent SPC cards are written. Alternate format with THRU in the fifth field is supported.
SPCD Constraints Defines an enforced displacement value for static analysis and an enforced motion value (displacement, velocity or acceleration) in dynamic analysis.
SUPORT Constraints Defines determinate reaction degrees-of-freedom in a free body.
SUPORT1 Constraints Defines determinate reaction degrees-of-freedom (r-set) in a free body-analysis. SUPORT1 must be requested by the SUPORT1 Case Control command.
TIC(D) Constraints Transient Initial Condition - Defines values for the initial conditions of variables used in structural transient analysis.
TIC(V) Constraints Transient Initial Condition - Defines values for the initial conditions of variables used in structural transient analysis.
TEMP Temperatures Defines temperature at grid points for determination of thermal loading, temperature-dependent material properties, or stress recovery.
TEMPBC Temperatures Defines the temperature boundary conditions for heat transfer analysis.
USET Constraints Defines a degree-of-freedom set.
USET1 Constraints Defines a degrees-of-freedom set.
OptiStruct Cards
General boundary conditions, such as loads and constraints, should not be collected into specific load collectors. Organizing loads and constraints into a specific load collector may result in an error termination.
ASET Constraints Defines the boundary degrees-of-freedom of a superelement assembly for matrix reduction.
ASET1 Constraints Defines the boundary degrees-of-freedom of a superelement assembly for matrix reduction.
DAREA Constraints Defines scale (area) factors for dynamic loads. DAREAは、RLOAD1、RLOAD2、TLOAD1、およびTLOAD2エントリと共に使用します。
DELAY Constraints Defines the time delay term τ in the equations of the dynamic loading function. DELAYは、RLOAD1、RLOAD2、TLOAD1、およびTLOAD2エントリと共に使用します。
DPHASE Constraints Defines the phase lead term θ in the equation of the dynamic loading function. DPHASEは、RLOAD1エントリおよびRLOAD2エントリと共に使用されます。
FORCE Force Defines a static force at a grid point or a SET of grid points by specifying a vector.
FORCE1 Force Used to define a static force by specification of a value and two grid points that determine the direction. RLOAD1、RLOAD2、TLOAD1、TLOAD2バルクデータエントリの動的荷重のEXCITEIDフィールド(倍率“A”)の定義に用いる事もできます。また、FORCE1エントリは、大変位非線形解析では追従荷重として定義できます。
MBFRC Force Defines a constant force at a grid point by specifying a vector.
MBFRCC Force Defines a curve force at a grid point by specifying a vector.
MBMNT Moment Defines a constant moment at a grid point by specifying a vector.
MBMNTC Moment Defines a curve moment at a grid point by specifying a vector.
MOMENT Moment Defines a static moment at a grid point or a SET of grid points by specifying a vector.
MOMENT1 Moment Defines a static moment by specification of a value and two grid points, which determine the direction. RLOAD1、RLOAD2、TLOAD1、TLOAD2バルクデータエントリの動的荷重のEXCITEIDフィールド(倍率A)の定義に用いる事もできます。
MOTNG Constraint Defines a constant grid point motion.
MOTNGC Constraint Defines a grid point motion vs. time by specifying a curve.
PLOAD Pressure Defines a static pressure load on a triangular or quadrilateral element. RLOAD1、RLOAD2、TLOAD1、TLOAD2バルクデータエントリの動的荷重のEXCITEIDフィールド(倍率 “A”)の定義に用いる事もできます。
PLOAD1 Pressure Defines concentrated, uniformly distributed, or linearly distributed applied loads to the CBAR or CBEAM elements or a SET of such elements at user-chosen points along the axis. RLOAD1、RLOAD2、TLOAD1、TLOAD2バルクデータエントリの動的荷重のEXCITEIDフィールド(倍率 “A”)の定義に用いる事もできます。
PLOAD2 Pressure Defines a uniform static pressure load applied to two-dimensional elements, or a SET of such elements.
PLOAD4 Pressure Defines a load on a face of a HEXA, PENTA, TETRA, PYRA, TRIA3, TRIA6, QUAD4, or QUAD8 element. RLOAD1、RLOAD2、TLOAD1、TLOAD2バルクデータエントリの動的荷重のEXCITEIDフィールド(倍率 “A”)の定義に用いる事もできます。また、PLOAD4エントリは、大変位非線形解析では追従荷重として定義できます。
QBDY1 Flux Defines a uniform heat flux for CHBDYE elements.
QVOL Flux Defines a rate of volumetric heat addition in a conduction element.
SPC Constraint Defines sets of single-point constraints, enforced displacements for static analysis, and thermal boundary conditions for heat transfer analysis.
SPCD Constraint Defines an enforced displacement value for static analysis, an enforced displacement, velocity or acceleration for dynamic analysis and a thermal boundary condition for heat transfer (or transient heat transfer) analysis. RLOAD1、RLOAD2、TLOAD1、TLOAD2バルクデータエントリの動的荷重のEXCITEIDフィールド(倍率 “A”)の定義に用いる事もできます。
SUPORT Constraint Defines determinate reaction degrees-of-freedom in a free body.
SUPORT1 Constraint Defines determinate reaction degrees-of-freedom in a free body.
TEMP Temperature Defines temperature at grid points or a SET of grid points for determination of Thermal Loading and Stress recovery.
TIC(D) or (V) Constraint Defines values for the initial conditions of variables used in structural transient analysis and explicit analysis. 変位および速度の値の両方を独立自由度で指定できます。
USET Constraint Defines a set of degrees-of-freedom.
USET1 Constraint Defines a set of degrees-of-freedom.
PAM-CRASH Cards
ACC3D / Acceleration Imposed accelerations
BOUNC / Constraints Define boundary condition
CONLO / Force(1) Concentrated nodal load
DIS3D / Constraints Imposed displacement
DIS3DM / Constraints Imposed minimum displacement
DIS3DX / Constraints Imposed maximum displacement
INVEL / Velocity Define initial velocity
PREFA / Pressure(1) Pressure on shells
RAC3D / Acceleration Imposed rotational acceleration
RAN3D / Constraints Imposed angular rotations
RDA3D / Acceleration Radial 3D boundary conditions
RDD3D / Constraints
RDV3D / Velocity Radial 3D boundary conditions
RVE3D / Velocity Imposed rotational velocities
RWALL / Rigid wall definition
SECFO_PLANE /
VEL3D / Velocity Imposed velocities
Permas Cards
$ADDMODES Constraints Definition of static mode shapes to be added to the set of eigenmodes used for transformation to modal space.
If static mode shapes will be added directly to nodes or nodesets (SOURCE=INPUT), the $ADDMODES can be created through the Constraints panel.
Click sysid to specify the system regarding to which the modes shall be applied.
Use the DOFTYPE button to select an option: DISP, TEMP, PRES, POTE and MATH.
$ADDMODES Pressure Definition of static mode shapes to be added to the set of eigenmodes used for transformation to modal space.
If mode shapes will be applied based on the natural deformation of elements (SOURCE=INPUT) the $ADDMODES keyword needs to be created here.
$CONLOAD Force Definition of concentrated loads at nodal point degrees of freedom.
$CONLOAD Moment Definition of concentrated loads at nodal point degrees of freedom.
$DISLOAD PRESS Pressure Definition of pressure loads for elements, where loads are given for elements or element sets.
Applicable to shells and solids, but also axisymmetric solid elements. Therefore please apply a pressure on an HM shell element. Face identifiers are written in this case. On import IDS ELNODES or NODES will be resolved into ELGEO (face identifiers).
$DISLOAD TEMP Pressure Nodal temperatures defined on elements or element sets.
$DISLOAD TEMPFILM Pressure Surrounding temperatures for convective heat transfer applied on elements or element sets.
$DISLOADN TEMP Temperature Nodal temperatures definition applied on nodes or node sets
$DISLOADN TEMPFILM Temperature Surrounding temperatures for convective heat transfer applied on nodes or node sets.
$INIVAL Constraints Definition of initial values for nodal point degrees of freedom.
For $INIVAL source parameter INPUT is currently supported to specify the initial values based on nodal points.
$INERTIA Pressure Definition of inertia forces acting on entire component or element sets. Available are force distributions due to linear acceleration, constant or accelerated rotation and coriolis acceleration.
Only ACCELERATION and GRAVITY are supported. This card is created in the Pressure panel. Assign to a set of elements, and the set statement displays in the card image. To create the card without a set, create a pressure on a 'dummy' element; the card will be created without a set and can be applied to the whole model.
$INERTIAX Pressure Definition of inertia forces acting on entire axisymmetric component or element sets. Available are force distributions due to linear acceleration and constant rotation.
$MPC GENERAL Equation Multipoint constraint definition.
The equation needs to be placed into a load collector with card image SUPRESS.
By attaching the load collector to a load step with ‘CONSTRAINTS’ attribute set, the $MPCVAL card gets written in the desired $CONSTRAINTS variant.
$PRESCRIBE/ PREVAL Constraints Prescribed degrees of freedom/Nodal point values (implemented as HyperMesh constraints)
$SUPPRESS Constraints Suppressed degrees of freedom
Radioss Cards
/ALE/BCS Constraint Describes the ALE boundary conditions.
/BCS Constraint Defines boundary conditions on node groups for translational and rotational motion.
/BCS/LAGMUL Constraint Defines boundary conditions on node groups using Lagrange multipliers. This keyword is not available for SPMD computation.
/CLOAD Force Defines a concentrated force applied to each node of a prescribed nodal group.
/CLOAD Moment Defines a concentrated moment applied to each node of a prescribed nodal group.
/CONVEC Thermal Describes the free or forced convective flux.
/DFS/DETCORD Pressure Set burning times of explosive material elements along a neutral fiber of detonating cord. Neutral fiber is provided with an ordered group of nodes and numerically built by spline interpolation.
/DFS/DETLINE Pressure Enable explosive material ignition from a detonation line [A,B]. Point A & B - XYZ coordinate.
/DFS/DETLINE/NODE Pressure Enable explosive material ignition from a detonation line [A,B]. Node ID defining Point A & B Coordinates.
/DFS/DETPLAN Pressure
Describes a planar detonation wave. Node identifier for base point P.
/DFS/DETPLAN/NODE Pressure
Describes a planar detonation wave. XYZ coordinate for basis point P.
/DFS/DETPOINT Pressure Locates the detonation point and set lighting time for an explosive material law, XYZ coordinates.
/DFS/DETPOINT/NODE Pressure Locates the detonation point and set lighting time for an explosive material law, node identifier defining ignition coordinates.
/DFS/LASER Pressure Enable to model laser impact taking into account laser-matter interaction.
/DFS/WAV_SHA Pressure Enables you to shape detonation wave to take into account obstacles.
/EBCS/GRADP0 Pressure Describes the elementary boundary condition sets. Keyword: Zero pressure gradient.
/EBCS/INIP Pressure Describes the elementary boundary condition sets. Keyword: Initial pressure.
/EBCS/INIV Velocity Describes the elementary boundary condition sets. Keyword: Initial velocity.
/EBCS/NORMV Velocity Describes the elementary boundary condition sets. Keyword: Imposed normal velocity.
/EBCS/PRES Pressure Describes the elementary boundary condition sets. Keyword: Imposed density and pressure.
/EBCS/VALVIN Pressure Describes the elementary boundary condition sets. Keyword: Inlet valve (Imposed density and pressure).
/EBCS/VALVOUT Pressure Describes the elementary boundary condition sets. Keyword: Outlet valve (Imposed density and pressure).
/EBCS/VEL Velocity Describes the elementary boundary condition sets. Keyword: Imposed velocity.
/GRAV Acceleration Defines gravity load on node group.
/IMPACC Acceleration Defines imposed accelerations on a group of nodes.
/IMPDISP Constraint Defines imposed displacements on a group of nodes.
/IMPDISP/FGEO Constraint Describes the final position of a set of N nodes, input by coordinates.
/IMPFLUX Thermal Defines an imposed thermal surface flux on the specified surfaces or a thermal volumetric flux on the specified bricks.
/IMPTEMP Thermal Defines imposed temperatures on a group of nodes.
/IMPVEL Velocity Defines imposed velocities on a group of nodes.
/IMPVEL/FGEO Velocity Describes the final position of a set of N nodes. The final position is provided by a node number. The node may eventually move.
/INITEMP Thermal Describes the initial nodal temperature.
/INIVEL/AXIS Velocity Initialize both translational and rotational velocities on a group of nodes in a given coordinate system.
/INIVEL/TRA Velocity
Defines initial velocity on a group of nodes.
Initial velocity type: TRA - Translational material velocity.
/INIVEL/ROT Velocity
Initial velocity type: ROT - Rotational material velocity.
/INIVEL/T+G Velocity
Initial velocity type: T+G - Translational and grid material velocity (only used for ALE material).
/INIVEL/GRID Velocity
Initial velocity type: GRID - Grid material velocity (only used for ALE material).
/LOAD/CENTRI Moment Apply a centrifugal force on a set of nodes according a body rotational velocity around the defined direction.
/LOAD/PFLUID Pressure Simulates hydrodynamic fluid pressure on a structure. The fluid pressure is calculated according to the specified fluid velocity, orientation of the structural surface against the fluid vector and the height of the fluid column above the surface of the structure.
/PLOAD Pressure Defines pressure load on a surface.
/RADIATION Thermal Describes the imposed radiation flux to environment.
/SPHBCS/SLIDE Constraint
Describes the SPH symmetry conditions.
Type: Material is perfectly sliding along the plane.
/SPHBCS/TIED Constraint
Type: Material cannot slide along the symmetry plane.
Samcef Cards
.CLM FIX Constraint Defines a set of single-point constraints
.CLM DEP Constraint Defines sets of enforced displacements
.CLM CHA COMP 123 Force Defines a static force at a grid point by specifying a vector and a value.
.CLM FOL COMP 123 Force Defines a follower force at a grid point by specifying a vector and a value
.CLM CHA COMP 456 Moment Defines a static moment at a grid point by specifying a vector and a value.
.CLM FOL COMP 456 Moment Defines a follower moment by specifying a vector and a value
.CLM PRESSURE Pressure Defines a static pressure load on any elements type
