Processing math: 100%
Kinematic Draping Theory
Layered composite structures are typically formed by placing reinforced plies against a mold surface in desired orientations.
In the case of flat and singly curved surfaces, the orientation of the ply stays practically unchanged over the whole application area. When it comes to doubly curved surfaces, a ply can follow the surface only by deforming. In particular, dry and pre-impregnated woven fabrics can adapt to the shape of a doubly curved surface without use of excessive force. Deformation occurs with in-plane shear and up to certain deformation level, the shear stiffness of the fabric is insignificantly small. [1]
When a ply deforms by shearing to follow the surface, the fiber orientation changes. Different approaches have been developed for the simulation of the so-called draping process. [2] The need for draping simulation is twofold. Firstly, the manufacturability of the composite product can be assessed. Areas where the reinforcement cannot follow the surface are indicated and hence measures can be taken in design to avoid this. Secondly, the draping simulation gives the actual fiber orientations at any location in the model. This information is needed for accurate finite element analysis of the structure.
The implemented method is the widely used kinematic draping. In this approach, a reinforced ply is idealized with a pin joint net model. [3, 4] The net consists of draping elements, which are constructed of inextensible bi-directional fibers that are pinned together at crossover node points. The deformation of the fabric takes place by pure rotation of the fibers around the pins as illustrated in the following image.
In the draping simulation, draping elements are laid one by one on the surface of the model so that they are fully in contact with the surface. The draping procedure involves the search for two types of draping elements: those with two or three known node points as shown in the following image. In case of three known node points, the search algorithm seeks the fourth node point from the surface so that the distances along the surface to the adjacent node points are equal to the draping element edge length.
Draping of the elements that have two known node points (left). Draping propagation is on initially orthogonal directions. Draping of the elements that have three known node points (middle). The coverage is based on the primary draping paths. Restart of the draping (right) and full coverage. For the restart the default Relaxation angle has been first used. Then, maximum Relaxation angle has been used. The associated model Revolution.hm can be found in tutorials\hm folder of your installation.
When two node points are known and the locations of the other two must be determined, the search algorithm is based on the minimization of the shear strain energy [5]:(1)
minE=12Gγ2
where G is the elastic shear modulus of the uncured reinforcement. The shear deformation is related to the angle alpha between the originally orthogonal fibers [2]:(2)
γcosα
The total shear strain energy of the draping element is defined as the sum of energy computed at the four corners. The two constants can be excluded, and the minimization problem becomes:(3)
minE=4i=1cos2αi
From this, the locations of the two node points can be determined with an iterative minimization algorithm.
The draping simulation starts from a given seed point and progresses in the given draping direction. In this phase each draping element has initially two known node points. Draping elements are laid until the model edge is reached. The procedure progresses simultaneously in all four primary directions (by default this is set to on), which are initially orthogonal. Parallel to the draping of primaries, the draping elements with three known nodes are populated. The algorithm resolves if the whole model is draped or if there are areas where the draping simulation needs to be restarted.
Restart is initiated from the middle of the draping patch edge. At the location of the restart, two nodes are known and the two unknowns need to be determined with the energy minimization. Without constraining, the solution typically yields a very relaxed draping mesh. User can control the recovery of the draping mesh with the relaxation angle parameter (default 3 degrees). This parameter limits the level of relaxation with respect to its parent draping element. Then, the algorithm sweeps the row of draping elements on the edge of concern, proceeds to other undraped edges and so on.
The simulation determines fiber principal directions 1 (warp) and 2 (weft). Draped fiber directions 1 are mapped to the finite element model to correct material orientations accordingly. Woven ply can be split to two unidirectional plies with ply orientations 0 and 90, respectively, and draped separately.
The shear angle gamma is defined as:(4)
γ=90α
It expresses the deviation from the ideal non-sheared case. The visualization of beta values over the model surface is useful for depicting problem areas. Shear values are mapped to the FE mesh and are available as absolute values. For most fabric reinforcements, the maximum deformation angle alpha is 30-40 degrees. [6] When a fabric is sheared to a specific deformation level, the shear force starts to increase radically with only little increase in the shear deformation. This limit is called the locking angle. Beyond this limit buckling can be observed. In the Kinematic Draping dialog, the default value for β is set to 55 degrees. The locking angle of a reinforcement can be determined experimentally. [7]
The pin joint net model is specifically developed for woven fabrics, but it has been proven to work for cross ply prepreg stacks and for single unidirectional plies when the deformation is moderate. [8]
Also, the flat pattern of the ply shape can be visualized and exported to a file. The example case has been derived from [9].
Figure 3.
References
  1. Deep drawing of fabric reinforced thermoplastics, Bergsma OK, Huisman J., In: Brebbia CA, de Wilde WP, Blain WR, editors. Computer aided design in composite material technology, New York: Springer, 1988. p. 323-334.
  2. Algorithms for draping fabrics on doubly-curved surfaces, Van der Ween F., Int J Numer Meth Eng 1991;31:1415-1426.
  3. The influence of accurate stretch data for reinforcements on the production of complex structural moldings. Part 1. Deformation of aligned sheets and fabrics, Potter KD., Composites 1979;10: 161-167.
  4. The draping of woven fabric preforms and prepregs for production of polymer composite components, Wang J et al. Composites: Part A 30 (1999) 757-765.
  5. Fabric draping simulation in composites manufacturing Part II. Analytical methods, Van West BP, Luby SC., J Adv Mater 1997;28(3):36-41.
  6. Experimental studies and analysis of the draping of woven fabrics, Mohammed U et al. Composites: Part A 31 (2000) 1409-1420.
  7. On the relationship between shear angle and wrinkling of textile composite preforms, Prodromou AG, Chen J. Composites: Part A 28A (1997) 491-503.
  8. Bias extension measurements on cross-plied unidirectional prepreg, Potter K. Composites: Part A 33 (2002) 63-73.
  9. Fitting a woven-cloth model to a curved surface: mapping algorithms, Aono M., Breen D.E. and Wozny M.J., Computer-Aided Design, Volume 26, Issue 4, April 1994, 278-292.
  10. A Geometry Information Based Fishnet Algorithm for Woven Fabric Draping in Liquid Composite Molding, Yang B, Jin T., Bi F. and Li J., ISSN 1392–1320 Materials Science (MEDŽIAGOTYRA). Vol. 20, No. 4. 2014.
