Composite Browser
Use the Composite Browser to create, organize, and manage composite modeling data.
The Composite Browser consolidates entities and tools used in ply-based models. Ply-based models can be created, edited, and reviewed from within the Composite Browser. Additionally, composite stress toolbox functionality (like ABD matrix calculation) is provided in the context menu of relevant entities.
Browser Interface
The Composite Browser interface.
- The top pane contains a hierarchical view of either ply-based, or zone-based composite data.
- The bottom pane contains the Entity Editor.
Views
Composite views.
View options appear at the top of the Composite Browser.
Laminate View
- Laminates
- Plies
- Shapes (sets)
- Properties
- Materials
- System Collectors
- Tables
- Plies can be dragged between the Unstacked Plies folder and the laminate in which they should be stacked.
- Ply order within a laminate can be manipulated by dragging one of more plies to a new location within the laminate.
- Interface Laminates and sublaminates can be defined by dragging one or more laminates into another laminate. The parent becomes an interface laminate and the children become sublaminates. For more information on this modeling technique, see Interface Laminates.
- Material, Ply and Laminate level composite stress toolbox calculations, accessed from the “Analyze” context menu option.
Zone View
- Laminate level composite stress toolbox calculations (like ABD matrix calculation), accessed from the “Analyze” context menu option.
- Editing of orientation, thickness and material of plies passing through a zone. Any changes will propagate to all zones which contain the edited ply.
Orientation Visualization
Common orientation methods.
- Ply 1 Direction – Displays ply 1 direction (fiber) orientations. If a drape table is assigned to the selected ply, drape corrections are included as part of the vector.
- Material Reference – Displays the x, y and z axes of the material reference orientation. This is the direction which ply orientations rotate from.
Composite Stress Toolbox
Composite stress tools functionality.
- Laminates (If plies have a shape defined by an element set, all zones of contain thickness in laminate. If one or more plies do not have shape defined, the full list of plies in the laminate is used).
- Zones
- Plies
- Materials
For more information, see Composite Stress Toolbox.
Solver-Specific Details
Details for various solvers.
Entities created in the Composite Browser are assigned the most common solver card for a typical ply-based model. Properties and Shapes are filtered based on solver card to only display appropriate cards for a ply-based model. Additionally, in the OptiStruct profile, the appropriate card is set for laminate and ply entities upon creation.
OptiStruct
Entity | Displayed Cards |
Property | PCOMPP |
Set | SET_ELEM, None |
Radioss
Property | PCOMPP |
Abaqus
Property | *SHELL_SECTION_COMPOSITE, with “Defined layers” unchecked |
Set | ELSET, None |
ANSYS
Property | SECTYPE, with TYPE=SHELL, PLIES=0 |
LS-DYNA
Property | SectShll |
Set | Shell, None |
Nastran
Property | PCOMPP |
Set | SET, None |
Context Menu
Access additional composite options from the Composite Browser right-click context menu.
