Prefix All Curves with an Iteration Identifier
  1. To display the Parameters Browser, click View > Parameter Browser in any client beside HyperMesh.
  2. Right-click within the white space of the browser and select Expand All.
    The browser is expanded to show the entire contents of the session.
  3. Right-click on a curve and select Select All from the context menu.
  4. Activate the checkbox next to Name.
    A new row is added to the lower portion of the parameter table.
  5. Click the ellipse button, , next to the default curve name to display the More Options dialog.
  6. In the Name field, enter Run ID:.
  7. Change Value type to Prefix.
  8. Change Default value to Run 1.
  9. Click OK.
  10. Click Save, , to save the script template.
  11. Click OK.
  12. Click File > Session > Flexible Reports to display the Flexible Report Templates dialog.
  13. In the Run ID field, enter Run 2.
  14. Click Apply.
    The session is recreated and all curve names have Run 2 at the start of their name.
