Import and Export CSV Files
You can import and export comma separated value files (CSV) to and from TableView. There are two ways to access this feature:
  1. From the File menu, select Import > Import CSV or Export > Table CSV.
Or
  1. TableView supports multiple lines of data in a single cell. To add a line break, press Alt + Enter. The Conditional Formatting and the Cell Data panels are disabled if you select a cell that contains multiple lines or if you press Alt + Enter.
