fatigueprep
Translate files.
Translates Altair .h3d flexbody files into Ncode .fes/.asc files.
Translates Ncode .dac files into Altair .abf files.
Translates ADAMS .res files (modal participation factors) into Ncode .dac format.
Translates ADAMS .req files into Ncode .dac format.
fatigueprep <source> .h3d <target> .fes
fatigueprep <source> .h3d <target> .asc
fatigueprep <source> .dac <target> .abf
fatigueprep <source>.res <target>.dac
fatigueprep <source> .req <target> .dac [options]
Options
ADAMS .req files >> Ncode .dac files
<source>.req
Specifies the name of the ADAMS .req source file.
Specify the following options to filter what gets extracted:
YTYPE:<DISP|FORCE|VEL|ACC|USER>
YREQUESTID:<id#>
YCOMPONENT: <X|Y|Z|RX|RY|RZ|MAG|RMAG>
Note: Not specifying an option will cause everything in that category to be extracted.
A .dac file will be created for each vector of data. Two numbers separated by an underscore will be appended to the <target> basename for each flexbody ID and mode ID.
