HyperView Moldflow Results Reader
HyperView supports the Patran neutral format for post-processing Moldflow results.
Moldflow can export Patran format files using a Visual Basic script. To export the results into the Patran format, run the patout.vbs script using the Play macro tool option from the Tools menu in Moldflow. Refer to the Moldflow documentation for complete information on obtaining and using the patout.vbs script.
After you have run the patout.vbs script, you will have several ASCII result files that are prefixed with pat_ and have the file extension .ntr.
Supported Results
Data Name Results Type Data Type
Velocity (3D) NODE VECTOR
Fill Time NODE SCALAR
Grow from NODE SCALAR
Pressure NODE SCALAR
Pressure (end of filling) NODE SCALAR
Pressure at V/P switchover NODE SCALAR
Temperature at flow front NODE SCALAR
Extension rate (3D) (s) NODE SCALAR
Shear rate (3D) (s) NODE SCALAR
Shear rate, maximum NODE SCALAR
Temperature (3D) (s NODE SCALAR
Viscosity NODE SCALAR
Average velocity ELEMENT VECTOR
Orientation at core ELEMENT VECTOR
Orientation at skin ELEMENT VECTOR
Bulk temperature ELEMENT SCALAR
Bulk temperature (end of filling) ELEMENT SCALAR
Flow rate, beams ELEMENT SCALAR
Frozen layer fraction ELEMENT SCALAR
Shear rate, bulk ELEMENT SCALAR
Shear stress at wall ELEMENT SCALAR
Throughput ELEMENT SCALAR
Loading the Results in HyperView
Load the .UDM model files in HyperView following the standard procedure for loading model and results with one file with the Load Model panel. Click Apply; HyperView will create a model content table and results table for post-processing.
