HyperView MARC Results Reader
HyperView supports MARC t16 files for version 2008 r1.
Model Import
The following element types are supported:
Element Type Element Configuration
3 Plane stress quadrilateral.
5 Beam column
6 Two-dimensional, plane strain, three-node triangle.
7 Eight-node, isoparametric, three-dimensional hexahedron.
Note: It could also be a distorted cube. HyperView treats it as penta.
9 Three-dimensional truss.
10 Arbitrary quadrilateral ax symmetric ring.
11 Arbitrary quadrilateral plane-strain.
15 Axisymmetric, curved, thin-shell element.
18 Four-node isoparametric membrane.
21 Three-dimensional 20-node brick.
22 Quadratic thick shell element.
26 Plane stress, eight-node distorted quadrilateral.
27 Plane strain, eight-node, distorted quadrilateral.
28 Axisymmetric, eight-node distorted quadrilateral.
30 Membrane, eight-node, distorted quadrilateral.
32 Plane strain, eight-node, distorted quadrilateral.
35 Three-dimensional 20-node brick, Herrmann formulation.
36 Three-dimensional, two-node, heat transfer link. (represented as bar).
37 Arbitrary planar triangle (heat transfer element).
39 Heat transfer element (planar bilinear quadrilateral).
41 Eight-node planar biquadratic quadrilateral (heat transfer element).
43 Three-dimensional eight-node brick (heat transfer element).
49 Finite rotation, linear, thin shell element.
52 Elastic beam.
55 Axisymmetric, eight-node, distorted quadrilateral.
68 Elastic four-node shear panel.
72 Bilinear constrained shell element.
75 Bilinear thick shell.
116 Arbitrary quadrilateral, axisymmetric ring, reduced integration.
117 Eight-node, 3D, first-order isoparametric element (arbitrarily distorted cube).
126 Axisymmetric, six-node, distorted triangle.
127 Three-dimensional, ten-node tetrahedron.
129 Axisymmetric, six-node, distorted triangle.
134 Three-dimensional, four-node tetrahedron.
136 Three-dimensional, arbitrarily distorted pentahedral.
138 Bilinear, thin-triangular, shell element.
139 Bilinear, thin-shell, element.
149 Three-dimensional, eight-node, composite brick element.
156 Axisymmetric, low-order, triangular element.
173 Three-node, 3D cavity, surface element.
174 Four-node, 3D cavity, surface element.
185 Three-dimensional, eight-node, solid shell.
202 Three-dimensional, fifteen-node, pentahedral.
Result Import
The following result data types are supported:
Data Type Data Name Post Code
Vectors Displacements
External applied forces
External force
Reaction forces
Velocity
Acceleration
Contact friction force
Tying forces
1
3
3
5
28
30
37
46
Nodal Scalars Temperature
Electric potential
External heat flux
External electric current
Reaction heat flux
External electric charge
Reaction electric charge
Contact normal stress
Contact normal force
14
17
15
21
16
18
19
34
35
Tensor Results (Solid and Shell Elements) Strain
Stress
Components of Plastic Strains
Components of total strains tensor
Components of stress tensor
Components of plastic strain tensor
Components of creep strain tensor
Components of cauchy stress tensor
Stresses in preferred director tensor
Stress in global coordinate system
1-6
11-16
21-26
301-306
311-316
321-326
331-336
341-346
391-396
411-416
Element Scalars Equivalent plastic strain
Equivalent creep strain
Total temperature
Increment of temperature
Equivalent mises stress
Thickness of element
Total swelling strain
Strain energy density
Volume
Equivalent cauchy stress
Failure indices associated with failure criteria
Equivalent elastic strain
Equivalent viscoplastic strain rate
Axial force
Components of interlaminar normal stress for composites
Components of interlaminar shear stress for composites
Elastic strain energy density
7
8
9
10
17
20
38
48
78
47
91-107
127
175
264
251
254
58
