HyperView LS-NIKE3D Result Reader
Supported Results
Data Name Components Result Type Data Type
Displacement   NODE VECTOR
Velocity   NODE VECTOR
Acceleration   NODE VECTOR
Temperature   NODE SCALAR
Stress   ELEMENT TENSOR3-D
Strain   ELEMENT TENSOR3-D
Effective plastic strain   ELEMENT SCALAR
Thickness   ELEMENT SCALAR
2-D Force mxx bending moment ELEMENT SCALAR
myy bending moment ELEMENT SCALAR
mxy bending moment ELEMENT SCALAR
qxx shear resultant ELEMENT SCALAR
qyy shear resultant ELEMENT SCALAR
nxx normal resultant ELEMENT SCALAR
nyy normal resultant ELEMENT SCALAR
nxy normal resultant ELEMENT SCALAR
1-D Force Axial force ELEMENT SCALAR
S shear resultant ELEMENT SCALAR
T shear resultant ELEMENT SCALAR
S bending moment ELEMENT SCALAR
T bending moment ELEMENT SCALAR
Torsional resultant ELEMENT SCALAR
Note: The Nike3-D reader supports element results at nodal and centroidal positions. If integration point results for brick elements are available, then they are pushed to the nearest corners. Centroidal results are calculated by averaging the integration point results.
