HyperView Interface with MADYMO
When you select a model or results file, HyperView automatically detects the file type and selects the proper reader to import the data. If more than one reader claims to support the selected file format, a dialog listing those readers is displayed. From this dialog, you can select the preferred reader.
To extract only a selected set of results, use the external translator HvTrans to create an H3D file.
Solver Interface Support
HyperView supports result files created from the MADYMO solver using the .kn3 or .kn file formats.
