Extract Points and Nodes
Use the Extract Points/Nodes tool to interpolate and divide an edge or line, and find the center of an arc, fillet, or multiple curve segments.
  1. From the Geometry ribbon, Points tool group, click the Extract Points/Nodes tool.
  2. From the drop-down menu below the tool, select whether to work with points or nodes.
  3. Extract points/nodes in the following ways:
    Option Description
    Interpolate Points/Nodes
    1. Click on a line.
    2. In the microdialog, enter the number of points/nodes to extract and press Enter.
      New points are organized in the same component as their source line.
    Tip:
    • Re-interpolate the number of points/nodes on the selected line by entering a new value in the microdialog and pressing Enter.
    • When interpolating from multiple lines, the same number of points/nodes will be created on each line and distributed evenly along their respective source line’s length.
    • When interpolating from a closed loop, the start and end points/nodes are the same, but separate points/nodes will be created at each location. To divide a circle into four equal lines, interpolate five points/nodes.
    Find Curve Center
    1. Click on an arc.
    2. In the microdialog, click .
      Note: When calculating the curve center of multiple lines, a single point/node is created at the best matching curve center of the combined lines.
    Figure 3.
