Stuck Node Creation
Use the Stuck Node Creation tool to create (double) RBE3 connection to "stick" nodes on QUAD or TRIA elements to make the node displacements following the element ones.
You can setup the ID for RBE3 generation upfront.
View new features for HyperWorks 2021.
Set up your sessions in HyperWorks and create report templates.
Rapidly change the shape of the FE mesh without severely sacrificing the mesh quality and create, edit, and apply shapes for subsequent design optimization studies.
HyperMesh composites modelings.
The Design Space environment is dedicated to topology optimization model build and setup. It facilitates rapid model creation by generating the voxel design space for a number of different use cases.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to be compatible with this release.
Create an assembly structure from a .csv file definition.
Create node-to-node CBUSH elements at the connector locations point/node or line.
Use the cfast converter tool to convert CFAST elements into CBAR/RBE3 (spiders). For thermoelastic analysis, the CFAST has no thermal expansion coefficient. CBAR is thermoelastic compatible.
Use the Linear Gap tool to create linear gap analysis cards for Nastran and OptiStruct.
Connect two dissimilar 2D shell meshes using RBE3 connection.
In the steps below, you will create zero length elements and review.
Use the marine tool set to streamline the creation of properties and 1D stiffener mesh using the info read from Marine CAD tools.
Use Squeak and Rattle Director tool set to create evaluation lines, evaluate them and optimize the interfaces to eliminate squeak and rattle issues.
