Rapidly change the shape of the FE mesh without severely sacrificing the mesh quality and create, edit, and apply
shapes for subsequent design optimization studies.
The Design Space environment is dedicated to topology optimization model build and setup. It facilitates rapid model creation by generating
the voxel design space for a number of different use cases.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to
be compatible with this release.
Use the Create Properties/Beam sections For Each Element tool to create a new property with the same ID as the element
by copying the existing 1D and 2D element property and assigning it to the component/part.
Create Property By Element ID
Use the Create Properties/Beam sections For Each Element tool to create a new property with the same ID as the element by copying the existing 1D and 2D element property and assigning it to the component/part.
