Rapidly change the shape of the FE mesh without severely sacrificing the mesh quality and create, edit, and apply
shapes for subsequent design optimization studies.
The Design Space environment is dedicated to topology optimization model build and setup. It facilitates rapid model creation by generating
the voxel design space for a number of different use cases.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to
be compatible with this release.
Create a quad dominant mapped mesh from orthogonal lines for global FE model creation. Bar/beam mesh will be created
around the edges. This is mainly used for the fuselage section.
Stiffened Panel Mesh
Create a quad dominant mapped mesh from orthogonal lines for global FE model creation. Bar/beam mesh will be created around the edges. This is mainly used for the fuselage section.
