Synch Between HyperMesh and HyperView
Allows you to have the same system defined in both HyperMesh and HyperView.
From the menu bar, click Aerospace > Systems > Synch HM-HV.
Restriction: Rectangular and cylindrical systems are currently supported.
Use cases for HyperMesh:
  • You have a session with a model in HyperMesh and the same model with results in one or more HyperView windows.
  • Create one or more coordinate systems in HyperMesh that have not been previously used in the model where the results have been extracted.
  • Open the tools in HyperMesh and select the system (s) you want to create in HyperView.
  • HyperView client (s) are displayed in a user interface where the systems that have to be created can be selected.
