F06 Parser
In Nastran, the F06 file contains information related either to the diagnostic of the model, analysis check up and results. This tool enables you to parse a defined number of information blocks and store them as a HyperMesh table entity with a given name.
Restriction: Only available in the Nastran solver.
From the menu bar, click Aerospace > Results > F06 Parser.
Information blocks are reported below:
  • Nastran version
  • Mass axis system
  • Model summary
  • Element geometric test results
  • OLOAD resultant
  • Decomposition blocks
  • SPC force resultant
  • Maximum SPC forces
  • Maximum displacements
  • Maximum applied loads
  • Max min summary
  • Stresses in quad elements
  • Stresses in tria elements
  • Eigenvalues
  • Ground check
  • Equilibrium check
  • Table of shift
Associated Tasks
You will provide the path to the relevant files that you want to process. The tool scans and parses these files that were created for each information block found among the ones above dedicated to the selected items.
You can select/deselect and rename the items that you want to have in the database as HyperMesh table entities.
