Compare Models
Use the Compare Models tool to compare the difference between two decks (ID comparison runs through offset).
  1. From the menu bar, click Aerospace > Assembly > Compare Models.
  2. Select the Reference file and Target file.
  3. Click Import Files.
  4. Select the Method.
    • Global: Comparison is performed showing the overall model characteristics.
    • Local: Comparison on either nodes or elements is performed selecting the associated attributes/data names. Levels of tolerance can be set up. You can highlight selected entities, report, create a set, import into the Matrix Browser, display marker or scalar plot.
  5. Click Perform Comparison.
