Change the Vector Color by Value
  1. From the View Controls toolbar, click .
  2. From the Vector panel, click the Display tab (located in the middle of the panel).
  3. Select Value from the Color by drop-down menu.
    The Edit Legend button becomes enabled in the Legend tab.
  4. From the Legend tab, click Edit Legend.
    Modify the legend values and colors in the Edit Legend dialog.
