Delete a Section Cut
  1. From the View Controls toolbar, click .
  2. In the Section Cuts panel, select a section cut from the Section Cuts list.
  3. Delete the section cut using one of the following methods.
    • Click Delete (located at the bottom of the panel).
    • Press Delete on the keyboard.
    The section cut is removed from the list and the model is returned to its normal state.
