Rename a Derived Load Case
  1. Do one of the following:
    • Click the Loadcase tool.
    • Right-click in the Results Browser and select Create > Derived Load Case then a load case type.
    The Create/Edit Derived Load Case dialog is displayed.
  2. From the Derived load case drop-down menu, select a load case to make it active.
  3. Click Rename.
    The Rename dialog is displayed.
  4. Type a new label in the text field and press Enter.
