Preparing nCODE FES and ASC Files from H3D Flexbody Files
nCODE fatigue software requires that the stress modes be represented in their FES file format. MotionView allows you to convert these modes from an H3D flexbody file to the nCODE FES file.
View new features for HyperWorks 2021.
Set up your sessions in HyperWorks and create report templates.
Rapidly change the shape of the FE mesh without severely sacrificing the mesh quality and create, edit, and apply shapes for subsequent design optimization studies.
HyperMesh composites modelings.
The Design Space environment is dedicated to topology optimization model build and setup. It facilitates rapid model creation by generating the voxel design space for a number of different use cases.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to be compatible with this release.
Use the marine tool set to streamline the creation of properties and 1D stiffener mesh using the info read from Marine CAD tools.
Use Squeak and Rattle Director tool set to create evaluation lines, evaluate them and optimize the interfaces to eliminate squeak and rattle issues.
MotionView is a general pre-processor for Multi-body Dynamics.
MotionView has many pre-processing and post-processing capabilities with regards to flexible bodies, or flexbodies, for multi-body dynamics models.
MotionView works with a HyperWorks neutral file called H3D to represent the flexible body. This compact file format stores the necessary information for visualizing the flexbody in the pre-processing window and the modes and interface nodes in the post-processing window. It also stores the modal and nodal information.
Once an H3D file is created, it can be visualized in HyperView.
MotionView models solved in MotionSolve or Adams can be animated in HyperView. In addition, the plots for these models can also be viewed in HyperGraph.
The Fatigue Prep custom wizard generates ADAMS output files from a flexbody transient run, which can then be used in nCODE Fatigue software. Finite element fatigue requires that flexbody mode shapes be an nCODE FES file, and the flexbody modal participation factors be "n" number of DAC files, where each DAC file contains the time history of a single mode's modal participation factor.
DAC files can be imported to and exported from HyperGraph.
nCODE fatigue software requires that each time history of modal participation factors be represented in the DAC file format, one file per time history. MotionView provides the conversion option from the ADAMS ASCII file to "n" number of DAC files, where "n" is the number of modes within the flexbody. MotionView modifies the base name accordingly so that unique filenames result.
DAC files can be converted to ABF files in two ways.
From the Preferences menu, you can access the Options dialog.
Reference material for the HyperWorks Desktop scripting interface which is a set of Tcl/Tk commands.
ON THIS PAGE
ON THIS PAGE
