Importing/Exporting DAC Files
DAC files can be imported to and exported from HyperGraph.
The hgdacwriter exports curve data to DAC files, one file per curve. If more than one curve is requested, the name of the output file is modified by adding the unique request name to the filename. To export curve data to DAC files, select Export Curves from the File menu.
See Export Curves for more information on using this feature.
