Defining an Expression Output
  1. From the Result Type drop-down menu, select Expressions to create an expression based output request.
  2. Click inside the F2: text box and enter the expression that needs to be printed to the result files.
    Tip: Use the Expression Builder to create complex expressions by clicking inside the desired text box and selecting from the trio of buttons at the top of the panel. The Expression Builder provides access to all solver function data members in the model, as well as many math and signal processing functions in HyperGraph.
  3. Enter expressions for the remaining five text boxes.
