Options Dialog - Mouse
The Options dialog, Mouse option allows you to customize mouse controls.
Figure 1. Options dialog - Mouse
See Tools Menu - Options - Mouse in the HyperView Online Help for a detailed explanation of mouse controls.
View new features for HyperWorks 2021.
Set up your sessions in HyperWorks and create report templates.
Rapidly change the shape of the FE mesh without severely sacrificing the mesh quality and create, edit, and apply shapes for subsequent design optimization studies.
HyperMesh composites modelings.
The Design Space environment is dedicated to topology optimization model build and setup. It facilitates rapid model creation by generating the voxel design space for a number of different use cases.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to be compatible with this release.
Use the marine tool set to streamline the creation of properties and 1D stiffener mesh using the info read from Marine CAD tools.
Use Squeak and Rattle Director tool set to create evaluation lines, evaluate them and optimize the interfaces to eliminate squeak and rattle issues.
MotionView is a general pre-processor for Multi-body Dynamics.
MotionView has many pre-processing and post-processing capabilities with regards to flexible bodies, or flexbodies, for multi-body dynamics models.
From the Preferences menu, you can access the Options dialog.
Various options for your model are set in the Options dialog.
Display options such as background color, foreground color, and mesh lines are set from the Options dialog.
Visualization options can be set using the Options dialog, Visualization option.
The Options dialog, Lighting option provides light sources for illuminating graphics.
The Check Model options allow you to select which information from the model file will be displayed when the Check Model
tool
is run.
The Options dialog, Build Model option allows you to set the standard include files and enable/disable the wizard related menu items in the menu bar.
The Options dialog, Path Management option allows you to set the file paths referenced by MDL entities as a relative or absolute path.
Reference material for the HyperWorks Desktop scripting interface which is a set of Tcl/Tk commands.
