Options Dialog - Lighting
The Options dialog, Lighting option provides light sources for illuminating graphics.
- One Light
- The controls in this dialog specify the position, shininess and speculiarity of the
light. Any combination of light properties may be used to light the graphic. Select
the Preview check box to immediately update the graphic when
manipulating light controls.
Direction The direction of the light is defined by moving the horizontal and vertical slide controls. Specular The specular color defines the color reflected back on shiny surfaces. Moving the slider bar from low to high controls the degree of shininess. To disable specular highlighting, set the specular color to black. Color To change the color of the graphic, click on a color box, select a new color from the palette, and click OK. Shininess Use the slider bar to set the shininess (0-128). Preview Activate the check box to preview the changes in the graphics area. - Multiple Lights
- Use the standard placement of multiple lights. The following option is
available:
