Disk Brakes Attachments
  • Front wheel spindle revolute joint pair: Revolute joint pair between front wheel hub and front knuckle.
  • Rear wheel spindle revolute joint pair: Revolute joint between rear wheel hub and rear knuckle.
Front Disk Brakes Attachments
  • Brake line pressure solver variable: solver variable front brake line pressure.
  • Wheel spindle revolute joint pair: Front wheel spindle revolute joint pair.
Rear Disk Brakes Attachments
Similar to front Disk brakes attachments (above).
