COSIN/io 2D Road Type: plank or cleat
COSIN/road searches for the data block $plank or $cleat, and reads:
Name of input variable Unit Meaning
height mm Height of plank/cleat.
start m Start of plank/cleat (travel distance).
length mm Length of plank/cleat, measured along x axis.
bevel_edge_length mm Length of bevel edge, measured along x axis. Bevel edge has 45deg slope. With edge_rounded = 1, rounded corners instead of bevel edges are used. In this case, bevel_edge_length is radius of the corner.
edge_rounded 0/1
1
Edge rounded
0
Edge linear, not rounded
direction deg Direction of plank/cleat relative to y axis.
direction = 0 if plank/cleat is placed crosswise.
mu_factor_cleat - Friction value factor on plank/cleat.
