COSIN/io 2D Road Type: hydropulse_harmonic
COSIN/road searches for the data block $hydropulse_harmonic, and reads:
Name of input variable Unit Meaning
frequency_flfrequency_frfrequency_rlfrequency_rr Hz Hydro-pulse excitation frequencies at front left / front right / rear left / rear right wheel.
amplitude_flamplitude_framplitude_rlamplitude_rr mm Hydro-pulse excitation amplitudes at front left / front right / rear left / rear right wheel. Set amplitude to zero, if the respective wheel is not to be excited.
phase_flphase_frphase_rlphase_rr deg Hydro-pulse phase angles at front left / front right / rear left / rear right wheel.
