Modify a Command Set Attachment
  1. From the Project Browser, select a command set.
    The Command Sets panel is automatically displayed.
  2. Select the Attachments tab.
  3. Select an attachment from the Attachment list.
    The entity currently referenced by the attachment is displayed in the collector. The field next to the collector also indicates what type of entity is being referenced by the attachment.
  4. Click the collector name to display the Select an "Entity" dialog.
  5. Select the entity to which you want to attach the collector.
  6. Click OK.
    The name of the selected entity appears next to the collector, and the attachment is made.
