Toggle between Overlaid Images
  1. Select a MediaView window with multiple video image files loaded.
  2. From the Media Overlay panel, activate the On toggle for any files to be overlaid.
  3. Click Apply.
    The MediaView window toggles between the current image for each selected data file.
    The number of flips for each image and the duration of each flip matches the values set on the panel.
