Change the Number of Flips and Duration
  1. Select a MediaView window with multiple video image files loaded.
  2. From the Media Overlay panel, activate the On toggle for any files to be overlaid.
  3. Enter new values in the Duration (seconds): field and the Number of flips: field.
  4. Click Apply.
    The MediaView window toggles between the current image for each selected data file.
    The duration of each flip and the number of flips match the new values set in the panel.
    Note: MediaView voids any invalid entries and resets the duration value to its default value.
