Filmstrip
Creates a 4x4 horizontal or vertical page layout that displays a series of frames for up to four media files at specified time offsets.
From the Media ribbon, click the Filmstrip tool to display the panel.
Filmstrip layout
Select Horizontal or Vertical for the filmstrip layout.
Files
Use the file browser button to select up to four media files to be displayed.
Offset between frames
Each successive window is offset by the amount entered. Negative offset values are not allowed. MediaView voids any invalid entries and resets the value to the default.
Fit image to window
Scales the video image to fit the image in the area of the window in which it is contained.
Time Scales...
Displays the Synchronize Animation dialog. Use this dialog to synchronize windows that contain animation results in different units and/or begin at different time steps.
