Create a New Filmstrip Page
  1. From the Filmstrip panel, under Filmstrip layout, select Horizontal or Vertical.
  2. Enter a value in the Offset between frames field.
  3. Under Files, click the file browser button and select a file.
  4. If you are using multiple movie files, repeat step 3 to select up to three additional movie files.
  5. Click Apply.
    Each successive window is offset by the amount entered.
    A new page is created with a 4x4 layout of the video images. The selected data file(s) is loaded into each window of either the first row or first column, depending upon the orientation.
    Note: Negative offset values are not allowed. MediaView voids any invalid entries and resets the value to the default.
    Tip: Select Fit image to window to scale the video image to fit in the window in which it is contained.
