Create a Curve from a Measure
Create curves from selected measures and place them on a plot.
  1. From the Home tools, click the Measure tool.
  2. From the Measures panel, select a measure from the Measures list.
  3. Click Create Curves.
    The Create Curves dialog is displayed.
  4. From the Plot Axes menu, choose the plot axes type from the following options:
    • Magnitude vs. Time
    • X vs. Time
    • Y vs. Time
    • Y vs. X
    • X vs. Y
  5. From the Place on drop-down menu, select a destination for the curve from one of the following options.
    Preview
    After selecting Preview, click OK. The curve is displayed in the Plot preview dialog. Click the X in the upper right corner to close the dialog.
    New
    After selecting New Plot, click OK. A plot is created in a HyperGraph window. The position of the plot in the window is based on the next available page layout.
    Existing
    Select a plot from the session tree to add the curve to the existing plot in HyperGraph. Click OK.
  6. Click OK to create a curve with the specified placement and plot axes in aHyperGraph window, using the selected units (if specified).
  7. Click Cancel to disregard the settings and exit the dialog.
